[GRASS-user] Export coordinates of 3D line feature into csv
format?
Rainer M Krug
r.m.krug at gmail.com
Fri Jul 8 09:57:31 EDT 2011
On Fri, Jul 8, 2011 at 1:16 PM, Micha Silver <micha at arava.co.il> wrote:
> On Fri, 2011-07-08 at 11:19 +0200, Rainer M Krug wrote:
> Hi
> I would like to export a 3D line feature into a csv format, as in:
> x y z
> 1 2 3
> I am not interested in the attribute tab;e, as I need the coordinates
> incl z.
Hi Micha,
> v.db.addcol <vectormap> col="x double precision, y double precision z
> double predision"
> Then put the values into those columns
> v.to.db <vectormap> option=coor column="x,y,z"
> Now export the attrib table as you did before.
This does unfortunately not work, as I have a line feature and not a point
feature - and I would like to extract the co-ordinates of all vertexes of
each line. I need this data, as I have to do some analysis afterwards for
which I need the z-co-ordinate of each vertex. I could convert the lines to
points, but how do I know which ones belong to which line and in which
order?
Rainer
> Is this possible? I only managed to export the attribute table so far
> (which I do not need...)
> Cheers,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
> UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel : +33 - (0)9 53 10 27 44
> Cell: +33 - (0)6 85 62 59 98
> Fax (F): +33 - (0)9 58 10 27 44
> Fax (D): +49 - (0)3 21 21 25 22 44
> email: Rainer at krugs.de
> Skype: RMkrug
> This mail was received via Mail-SeCure System.
> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
South Africa
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110708/7baa6d86/attachment.html
