[GRASS-user] Exporting labels of a raster
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Jul 14 05:14:50 EDT 2011
Just a slight off topic remark concerning the append text labels to your
grass raster layer. I think you might want to try out r.category. That way
you label your original raster rather then creating an additional (reclass)
layer with labels.
As for the question, I agree with previous comments, exporting the raster
and a separate text file with the legend is probably the best (only?) way to
go.
On Fri, Jul 1, 2011 at 2:20 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> On Fri, Jul 1, 2011 at 2:06 PM, Luisa Peña <luisapena1979 at gmail.com>wrote:
>> Hello Rainer
>> I'm using reclass in order to have a raster with text lables (land use
>> land cover class names). I thought that r.reclass would be the only way to
>> have that.
>> and My reclass file is something like this:
>> 1 = 1 Urban
>> 2 = 2 Agriculture
>> 3 = 3 Irrigated Agriculture
>> 4 = 4 Forests
>> 5 = 5 Shrubland
>> * = NULL
>> Do you have any alternative suggestion to have labels in LULC?
> It depends what you want to do with the raster.
> For labelling, this is the right approach.
> So when you use r.mapcalc "new_map=@existing_map"
> this will assume that the labels of your input map are numeric. Are your
> labels numeric or characters?
> From the help:
> RASTER MAP LAYER VALUES FROM THE CATEGORY FILE
> Sometimes it is desirable to use a value associated with a category's label
> instead of the category value itself. If a raster map layer name is preceded
> by the @ operator, then the labels in the category file for the raster map
> layer are used in the expression instead of the category value.
> For example, suppose that the raster map layer soil.ph (representing soil
> pH values) has a category file with labels as follows:
> cat label
> 0 no data
> 1 1.4
> 2 2.4
> 3 3.5
> 4 5.8
> 5 7.2
> 6 8.8
> 7 9.4
> Then the expression:
> result = @soils.ph
> would produce a result with category values 0, 1.4, 2.4, 3.5, 5.8, 7.2, 8.8
> and 9.4.
> Note that this operator may only be applied to raster map layers and
> produces a floating point value in the expression. Therefore, the category
> label must start with a valid number. If the category label is integer, it
> will be represented by a floating point number. I the category label does
> not start with a number or is missing, it will be represented by NULL (no
> data) in the resulting raster map.
> Cheers,
> Rainer
>> THanks
>> Luisa
>> 2011/7/1 Rainer M Krug <r.m.krug at gmail.com>
>>> On Fri, Jul 1, 2011 at 1:24 PM, Luisa Peña <luisapena1979 at gmail.com>wrote:
>>>> It didn't work. I get all full of NaNs map.
>>>> I used this:
>>>> input="LUlabel at Study"
>>>> grass.run_command("g.region", rast = input)
>>>> grass.mapcalc("$output= @$labels", labels=input, output="Giovanni2")
>>>> What am I doing wrong on this?
>>> NaN means Not a Number - were your labels non-numeric?
>>> I *think* that raster can only have numeric cell values
>>> Rainer
>>>> Luisa
>>>> 2011/7/1 Giovanni Manghi <giovanni.manghi at gmail.com>
>>>>> Hi,
>>>>> > I have a raster map to wich I have applied r.reclass to add labels to
>>>>> > raster classes. When I try to export this raster with the classes I
>>>>> > loose the lablels I only stick with the values.
>>>>> > In a script how can edit this raster in order to be exported with the
>>>>> > labels?Thanks
>>>>> then export "new_map" to tiff as usual.
>>>>> Cheers
>>>>> -- Giovanni --
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>>> Biology, UCT), Dipl. Phys. (Germany)
>>> Centre of Excellence for Invasion Biology
>>> Stellenbosch University
>>> South Africa
>>> Tel : +33 - (0)9 53 10 27 44
>>> Cell: +33 - (0)6 85 62 59 98
>>> Fax (F): +33 - (0)9 58 10 27 44
>>> Fax (D): +49 - (0)3 21 21 25 22 44
>>> email: Rainer at krugs.de
>>> Skype: RMkrug
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
> South Africa
> Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110714/41e21213/attachment.html
