[GRASS-user] GRASS Database doesn't copy correctly
    Rainer M Krug
    r.m.krug at gmail.com
    Thu Jul 21 06:03:37 EDT 2011
On Thu, Jul 21, 2011 at 11:56 AM, Daniel Lee <lee at isi-solutions.org> wrote:
> Hello there,
> Has anybody already had troubles copying the GRASS database to a server?
> I've just got the standard folder that GRASS uses to store its locations,
> mapsets and data, etc., and all I want to do is copy it over to a server
> that I have access to by copying the folder they're contained in (in this
> case it's called GRASS_Data). I've had problems with this before that not
> all of the data copies correctly and I just can't explain it. On my local
> hard drive the database has 120 GB and as soon as I copy it over to the
> server it's only got 74 GB. Other file operations work without problems,
> even when copying large amounts of data. This is the third attempt to copy
> the stuff; any clue why this is happening? Thanks!
OS desktop and server? permission issues? Are hidden files copied? is the
server hdd full? File system on desktop and server? If the desktop allows
files >4GB, does the server as well? How did you copy?
What about archiving on desktop, and extracting archive on server?
Questions over questions.
Cheers,
Rainer
> Daniel
> B.Sc. Daniel Lee
> Geschäftsführung für Forschung und Entwicklung
> ISIS - International Solar Information Solutions
> Deutschhausstr. 10
> 35037 Marburg
> Festnetz: +49 6421 379 6256
> Mobil: +49 176 6127 7269
> E-Mail: Lee at isi-solutions.org
> Web: http://www.isi-solutions.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax (F):       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110721/12beb29d/attachment.html
