[GRASS-user] flow accumulation
Rainer M Krug
r.m.krug at gmail.com
Thu Jul 21 09:35:00 EDT 2011
On Thu, Jul 21, 2011 at 3:30 PM, frans-joost <fjboogert at gmail.com> wrote:
> Dear GRASS users,
> I'm trying to implement the Morgan Morgan Finney model for erosion
> estimation.
> One problem I'm having is with the accumulation of surface runoff.
> Is it possible to sum all cells that are uphill, meaning each individual
> cell has an amount of water that flows downslope.
> It should be possible to use a flow direction map to accomplish this.
> r.terraflow does not have an option to accumulate using another map
> r.watershed gives me very high and negative values (not sure what happened
> there)
This goes in the direction what I am trying to do with seed dispersal via
water, and I did not get any responses - maybe not possible?
Rainer
> Thank you in advance
> Frans-Joost
> http://osgeo-org.1803224.n2.nabble.com/flow-accumulation-tp6606761p6606761.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110721/0c8e8e6b/attachment.html
