[GRASS-user] GRASS Database doesn't copy correctly
Daniel Lee lee at isi-solutions.org
Fri Jul 22 18:09:20 EDT 2011
I tried compressing it and moving the compressed file to the server, that
worked. I'd never heard of rsync before - that sounds like an elegant
solution, I'll try that one. Otherwise I at least have the tarball version
on the server now. Thanks!
On Thu, Jul 21, 2011 at 12:30 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> On Thu, Jul 21, 2011 at 12:12 PM, <Lee at isi-solutions.org> wrote:
>> > OS desktop and server? permission issues? Are hidden files copied? is
>> the server hdd full? File system on desktop and server? If the desktop
>> allows files >4GB, does the server as well? How did you copy?
>> > What about archiving on desktop, and extracting archive on server?
>> > Questions over questions.
>> Good question questions ;)
>> OS desktop is OpenSUSE 11.4, permission issues might have been the problem
>> but I made sure by trying to copy them this time as root (this computer
>> recognizes the folder as belonging to root, for whatever reason, so
>> theoretically I would have had issues, although I never do with the other
>> computers). Hidden files should be copied - I did a drag and drop operation
>> with the file manager and that should copy hidden files contained in the
>> copied folders (at least that's the way it works when I test it out on my
>> desktop, but since the command behind the copying is probably cp it should
>> work the same when I copy it to a server). Server HDD still has lots of
>> room, more than a TB. File system is on the desktop is Ext4, I can't find
>> any documentation on the NAS server but it's a Black Armor from Seagate and
>> I assume it's NTFS internally. I use CIFS to talk to it. It's definitely got
>> files on it that are > 4 GB.
>> Archiving on the desktop and moving the archive to the server is a good
>> idea, I'll try it out and report back :)
> Or you could try rsync - usually the best for these kind of things.
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
> UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax (F):       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110723/12d2a250/attachment.html
