[GRASS-user] Defining a State Plane Coordinate Location
Rich Shepard
rshepard at appl-ecosys.com
Fri Jul 22 18:48:53 EDT 2011
I've not before worked with SPCS in GRASS. I now need to define a new
location based on the SPCS for Nevada (East), and need to do this manually.
According to the startup page if I specify
$ grass65 /home/rshepard/grassdata/Nevada-SPCS/PERMANENT
will this make the above the CWD? If so, I assume that I immediately run
g.setproj and specify 'stp' as the projection name. What reference should I
use for the projection parameters?
Rich
