[GRASS-user] Defining a State Plane Coordinate Location
Markus Neteler
neteler at osgeo.org
Sun Jul 24 04:02:13 EDT 2011
On Sat, Jul 23, 2011 at 12:48 AM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> I've not before worked with SPCS in GRASS. I now need to define a new
> location based on the SPCS for Nevada (East), and need to do this manually.
> According to the startup page if I specify
> $ grass65 /home/rshepard/grassdata/Nevada-SPCS/PERMANENT
> will this make the above the CWD? If so, I assume that I immediately run
> g.setproj and specify 'stp' as the projection name. What reference should I
> use for the projection parameters?
I wouldn't do it this way.
Better use
- the wxGUI location manager from the startup screen
- or create the location from a GIS file (shape, geotiff, ..) with correct
metadata
- or create from the EPSG code
(is it this one?http://spatialreference.org/ref/epsg/3429/ )
Markus
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
