[GRASS-user] I'm in a hole and want to stop digging [SOLVED]
Rich Shepard rshepard at appl-ecosys.com
Wed Jul 27 11:24:45 EDT 2011
On Wed, 27 Jul 2011, Richard Chirgwin wrote:
> My approach - I use MySQL but don't see why this would not work in pg - is to
> associate a schema to a mapset. So if I want PERMANENT and Project, over in
> MySQL I might run:
> create database Master
> create database Project
Richard,
   When I stepped back to look at the forest instead of the individual trees
I appreciate that I should have understood this; except I've not before
worked with an external database. Mea culpa!
   Since each mapset has it's own dbf/ directory for GRASS-internal vector
attributes, each mapset needs it's own external database, too.
   g.copy now works.
Thank you,
Rich
