[GRASS-user] Re: r.li.setup
Ravinder Singh Bhalla rsbhalla at gmail.com
Sat Jul 30 00:10:53 EDT 2011
Dear All,
I've been trying to send this to the list for the past few weeks, seems
my mails are being blocked. Anyway, here's another attempt.
I've been trying to use the r.li suite in a landscape ecology course and
found the r.li.setup fails to create configuration files if one tries to
setup the sampling frame by drawing regions or by using vector layers.
The moving window, however, works.
Any suggestions on how to overcome this?
Thanks,
Ravi
Config file for region (2 regions were attempted but the input dialoge
did not allow me to digitise the regions of interest.)
SAMPLINGFRAME 0|0|1|1
MASKEDSAMPLEAREA 0.0|0.0|1.0|1.0|one
MASKEDSAMPLEAREA 0.0|0.0|1.0|1.0|two
Config file for vector input (vector comprised of 6 polygons)
On Sunday 03 April 2011 05:22 AM, Hamish wrote:
> Nani wrote:
>> r.li.setup
>> How to install, Where to find it, how is it provided,
> r.li.* is not provided in WinGrass. Only on UNIX builds (Mac or
> Linux). If you want to use these modules, you may also try the
> Cygwin build of GRASS for MS Windows, or try the older r.le
> modules.
>> what is it supposed this command do.
> see  http://grass.osgeo.org/grass64/manuals/html64_user/r.li.html
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
