[GRASS-user] ARC GRID File Won't Import
Rich Shepard
rshepard at appl-ecosys.com
Sat Jul 30 10:04:32 EDT 2011
On Sat, 30 Jul 2011, Daniel Victoria wrote:
> I believe the location should be just nevada-ll and not the entire directory.
> You only have to put the directory if the grass database is different.
Daniel,
You are correct. In the past I got an error if I did not specify the
absolute path to the location so this is a change from past behavior.
Thank you. That fixed the problem.
Rich
