[GRASS-user] GRASS 6.41, Ubuntu 10.10, spearfish,
v.db.join error DBMI-Postgres
driver error: [. . .] ERROR: value too long for type character(1)
Katie U
bracket at comcast.net
Fri Jun 10 10:25:13 EDT 2011
Friends,
This is a newbie question about working with the PostgresSql database
driver and grass vector mapsets.
I am learning GRASS and Postgres, and not working on any particular
project, although my next goal is to be able to use US Census data.
For now, I'm using spearfish data, with the example in the v.db.join
manual page. I did migrate the mysoils mapset to a mapset that is
connected to a PostGres DBMI. The instructions are mostly useful up to
the join, where an error occurs.
The error text is at the end of this message.
The help that I seek is first, a reference to other tutorials that
discuss joins and or layers, or for the patient, a quick look through my
notes here and a reply with some good hints
to build a mapset to visualize categories of vector data.
Many thanks,
Katie Urey
Portland, Oregon US
some details about the error:
My System: Ubuntu 10:10
My Grass Version and Environment:
GRASS 6.4.1 (2011)
GISDBASE=/home/GrassWork
LOCATION_NAME=spearfish60
MAPSET=spearfish_pg
GRASS_DB_ENCODING=utf-8
MONITOR=cairo7
GRASS_GUI=wxpython
My database environment to setup a join: postgres:
VERSION = 'PostgreSQL 8.4.8 on i686-pc-linux-gnu, compiled by GCC
gcc-4.4.real (Ubuntu/Linaro 4.4.4-14ubuntu5) 4.4.5, 32-bit'
DBNAME = 'spearfish'
USER = 'katie'
PORT = '5432'
ENCODING = 'UTF8'
I start grass, and at the command line, connect to the database, confirm
:~ > db.tables -p driver=pg | grep -v info
public.soils_legend
:~ >v.db.connect -p map=mysoils_pg
Vector map <mysoils_pg at spearfish_pg> is connected by:
layer <1> table <public.mysoils_pg> in database <spearfish> through
driver <pg> with key <cat>
:~ > v.db.join --v map=mysoils_pg column=label
otable=public.soils_legend ocolumn=shortname
DBMI-Postgres driver error:
Cannot execute:
UPDATE public.mysoils_pg SET id=(SELECT id
FROM public.soils_legend WHERE
public.soils_legend.shortname=public.mysoils_pg.label)
ERROR: Error while executing: 'UPDATE public.mysoils_pg SET id=(SELECT id
public.soils_legend.shortname=public.mysoils_pg.label)'
Cannot execute:
UPDATE public.mysoils_pg SET shortname=(SELECT shortname
Cannot execute:
UPDATE public.mysoils_pg SET longname=(SELECT longname
---- end of error---
No data is transferred, columns are setup with width=1.
~ > db.select mysoils_pg | head -3
cat|label|id|shortname|longname
1|Aab|||
2|Ba|||
