[GRASS-user] Grass-Windows - Error using tcltk's messages
Luisa Peña
luisapena1979 at gmail.com
Fri Jun 17 07:35:02 EDT 2011
Ok...
But the weirdeist thing is that it works on compiled version but when I try
to create an installer, it does not work at all (for all interfaces). Any
comments on this?
Thanks
2011/6/15 Maris Nartiss <maris.gis at gmail.com>
> Hello,
> as goes for windows users - they are out of luck. You can try to
> simply copy self compiled/nightly v.digit over old version, still I
> have no idea if it could work. On Linux it's just a matter of
> recompiling only v.digit module.
> Maris.
> 2011/6/9, Luisa Peña <luisapena1979 at gmail.com>:
> > Hello Markus. Thank you for your reply
> > In my case I'm using an older version of grass 6.4.1 over which I built a
> > lot of functions and change the GUi (a lot) in order to meet my users
> > (colleagues and teachers) needs. What can I do to fix this?
> > Thanks
> > 2011/6/9 Markus Neteler <neteler at osgeo.org>
> >> On Tue, Jun 7, 2011 at 5:35 PM, Luisa Peña <luisapena1979 at gmail.com>
> >> wrote:
> >> > Greetings
> >> > I have compiled GRASS6.4 with Osgeo4w and it worked just fine. Then I
> >> > decided to create an installer and it worked just fine but... tcltks
> >> > translation is not working. I only need the v.digit . And it's not
> >> working
> >> > for any language. Any tips on what might be happening?
> >> The messages were not tagged for translation in GRASS 6.4.
> >> I have backported that now, still have to update the .po files
> >> (asap).
> >> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110617/0493baec/attachment.html
