[GRASS-user] Grass7 r.in.lidar compile error
Pierre Roudier
pierre.roudier at gmail.com
Tue Jun 21 03:03:03 EDT 2011
I had the problem a few weeks ago.
In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
couldn't find ogr_srs_api.h
I edited /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h
and turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the
error and compiled properly.
Must be a change in the GDAL install. Any better idea welcome - this
is really just a hack.
Pierre
2011/6/21 Daniel Victoria <daniel.victoria at gmail.com>:
> Hi all,
> I just checked out the latest grass 7 from svn (r 46749) and tried to
> compile with the liblas option but I'm seeing the following error in
> r.in.lidar. It says I'm missing ogr_srs_api.h.
> I'm running Ubuntu 9.10 (I know, very old distro)
> Thanks
> Daniel
> daniel at xadrez:~/grass/grass_trunk/raster/r.in.lidar$ make
> gcc -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include
> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
> -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/main.o -c main.c
> In file included from main.c:26:
> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
> error: ogr_srs_api.h: No such file or directory
> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84:
> error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
> ‘GPJ_grass_to_osr’
> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88:
> error: expected declaration specifiers or ‘...’ before
> ‘OGRSpatialReferenceH’
> main.c: In function ‘main’:
> main.c:281: warning: format not a string literal and no format arguments
> main.c:296: warning: format not a string literal and no format arguments
> main.c:376: warning: format not a string literal and no format arguments
> main.c:379: warning: format not a string literal and no format arguments
> main.c:391: warning: format not a string literal and no format arguments
> main.c:485: warning: format not a string literal and no format arguments
> main.c:497: warning: format not a string literal and no format arguments
> main.c:560: warning: format not a string literal and no format arguments
> main.c:579: warning: format not a string literal and no format arguments
> main.c:596: warning: format not a string literal and no format arguments
> main.c:757: warning: format not a string literal and no format arguments
> main.c:1104: warning: format not a string literal and no format arguments
> main.c: In function ‘scan_bounds’:
> main.c:1127: warning: format not a string literal and no format arguments
> main.c:1178: warning: format not a string literal and no format arguments
> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Scientist
Landcare Research, New Zealand
