[GRASS-user] Grass7 r.in.lidar compile error
Daniel Victoria
daniel.victoria at gmail.com
Tue Jun 21 08:28:58 EDT 2011
Hi Pierre,
I did the same thing you did and Grass compiled without errors. The
only difference is that I changed the file in grass_trunk/include.
Apparently, everything is working OK.
Cheers
Daniel
On Tue, Jun 21, 2011 at 4:03 AM, Pierre Roudier
<pierre.roudier at gmail.com> wrote:
> I had the problem a few weeks ago.
> In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
> couldn't find ogr_srs_api.h
> I edited /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h
> and turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the
> error and compiled properly.
> Must be a change in the GDAL install. Any better idea welcome - this
> is really just a hack.
> Pierre
> 2011/6/21 Daniel Victoria <daniel.victoria at gmail.com>:
>> Hi all,
>> I just checked out the latest grass 7 from svn (r 46749) and tried to
>> compile with the liblas option but I'm seeing the following error in
>> r.in.lidar. It says I'm missing ogr_srs_api.h.
>> I'm running Ubuntu 9.10 (I know, very old distro)
>> Thanks
>> Daniel
>> daniel at xadrez:~/grass/grass_trunk/raster/r.in.lidar$ make
>> gcc -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include
>> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
>> -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include -o
>> OBJ.i686-pc-linux-gnu/main.o -c main.c
>> In file included from main.c:26:
>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
>> error: ogr_srs_api.h: No such file or directory
>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84:
>> error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>> ‘GPJ_grass_to_osr’
>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88:
>> error: expected declaration specifiers or ‘...’ before
>> ‘OGRSpatialReferenceH’
>> main.c: In function ‘main’:
>> main.c:281: warning: format not a string literal and no format arguments
>> main.c:296: warning: format not a string literal and no format arguments
>> main.c:376: warning: format not a string literal and no format arguments
>> main.c:379: warning: format not a string literal and no format arguments
>> main.c:391: warning: format not a string literal and no format arguments
>> main.c:485: warning: format not a string literal and no format arguments
>> main.c:497: warning: format not a string literal and no format arguments
>> main.c:560: warning: format not a string literal and no format arguments
>> main.c:579: warning: format not a string literal and no format arguments
>> main.c:596: warning: format not a string literal and no format arguments
>> main.c:757: warning: format not a string literal and no format arguments
>> main.c:1104: warning: format not a string literal and no format arguments
>> main.c: In function ‘scan_bounds’:
>> main.c:1127: warning: format not a string literal and no format arguments
>> main.c:1178: warning: format not a string literal and no format arguments
>> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Scientist
> Landcare Research, New Zealand
