[GRASS-user] Grass7 r.in.lidar compile error
Markus Metz
markus.metz.giswork at googlemail.com
Wed Jun 22 09:51:08 EDT 2011
On Tue, Jun 21, 2011 at 2:28 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi Pierre,
> I did the same thing you did and Grass compiled without errors. The
> only difference is that I changed the file in grass_trunk/include.
> Apparently, everything is working OK.
There was a compile flag missing for r.in.lidar, granted that
v.in.lidar was compiling ok without your fix. I have added the missing
compile flag to r.in.lidar, it should now compile without changing any
files in grass_trunk/include.
Markus M
> Cheers
> Daniel
> On Tue, Jun 21, 2011 at 4:03 AM, Pierre Roudier
> <pierre.roudier at gmail.com> wrote:
>> I had the problem a few weeks ago.
>> In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
>> couldn't find ogr_srs_api.h
>> I edited /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h
>> and turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the
>> error and compiled properly.
>> Must be a change in the GDAL install. Any better idea welcome - this
>> is really just a hack.
>> Pierre
>> 2011/6/21 Daniel Victoria <daniel.victoria at gmail.com>:
>>> Hi all,
>>> I just checked out the latest grass 7 from svn (r 46749) and tried to
>>> compile with the liblas option but I'm seeing the following error in
>>> r.in.lidar. It says I'm missing ogr_srs_api.h.
>>> I'm running Ubuntu 9.10 (I know, very old distro)
>>> Thanks
>>> Daniel
>>> daniel at xadrez:~/grass/grass_trunk/raster/r.in.lidar$ make
>>> gcc -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include
>>> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
>>> -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include -o
>>> OBJ.i686-pc-linux-gnu/main.o -c main.c
>>> In file included from main.c:26:
>>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
>>> error: ogr_srs_api.h: No such file or directory
>>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84:
>>> error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>> ‘GPJ_grass_to_osr’
>>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88:
>>> error: expected declaration specifiers or ‘...’ before
>>> ‘OGRSpatialReferenceH’
>>> main.c: In function ‘main’:
>>> main.c:281: warning: format not a string literal and no format arguments
>>> main.c:296: warning: format not a string literal and no format arguments
>>> main.c:376: warning: format not a string literal and no format arguments
>>> main.c:379: warning: format not a string literal and no format arguments
>>> main.c:391: warning: format not a string literal and no format arguments
>>> main.c:485: warning: format not a string literal and no format arguments
>>> main.c:497: warning: format not a string literal and no format arguments
>>> main.c:560: warning: format not a string literal and no format arguments
>>> main.c:579: warning: format not a string literal and no format arguments
>>> main.c:596: warning: format not a string literal and no format arguments
>>> main.c:757: warning: format not a string literal and no format arguments
>>> main.c:1104: warning: format not a string literal and no format arguments
>>> main.c: In function ‘scan_bounds’:
>>> main.c:1127: warning: format not a string literal and no format arguments
>>> main.c:1178: warning: format not a string literal and no format arguments
>>> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> Scientist
>> Landcare Research, New Zealand
