[GRASS-user] Grass7 r.in.lidar compile error
Pierre Roudier
pierre.roudier at gmail.com
Sat Jun 25 05:15:33 EDT 2011
Thanks Markus - I'm glad there's a cleaner solution than that dirty hack!
I'll test it ASAP,
Pierre
2011/6/22 Markus Metz <markus.metz.giswork at googlemail.com>:
> On Tue, Jun 21, 2011 at 2:28 PM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
>> Hi Pierre,
>> I did the same thing you did and Grass compiled without errors. The
>> only difference is that I changed the file in grass_trunk/include.
>> Apparently, everything is working OK.
> There was a compile flag missing for r.in.lidar, granted that
> v.in.lidar was compiling ok without your fix. I have added the missing
> compile flag to r.in.lidar, it should now compile without changing any
> files in grass_trunk/include.
> Markus M
>> Cheers
>> Daniel
>> On Tue, Jun 21, 2011 at 4:03 AM, Pierre Roudier
>> <pierre.roudier at gmail.com> wrote:
>>> I had the problem a few weeks ago.
>>> In file /usr/local/src/grass7-svn/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h,
>>> couldn't find ogr_srs_api.h
>>> I edited /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gprojects.h
>>> and turned ogr_srs_api.h to gdal/ogr_srs_api.h and it did pass the
>>> error and compiled properly.
>>> Must be a change in the GDAL install. Any better idea welcome - this
>>> is really just a hack.
>>> Pierre
>>> 2011/6/21 Daniel Victoria <daniel.victoria at gmail.com>:
>>>> Hi all,
>>>> I just checked out the latest grass 7 from svn (r 46749) and tried to
>>>> compile with the liblas option but I'm seeing the following error in
>>>> r.in.lidar. It says I'm missing ogr_srs_api.h.
>>>> I'm running Ubuntu 9.10 (I know, very old distro)
>>>> Thanks
>>>> Daniel
>>>> daniel at xadrez:~/grass/grass_trunk/raster/r.in.lidar$ make
>>>> gcc -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include
>>>> -D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
>>>> -I/home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include -o
>>>> OBJ.i686-pc-linux-gnu/main.o -c main.c
>>>> In file included from main.c:26:
>>>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
>>>> error: ogr_srs_api.h: No such file or directory
>>>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:84:
>>>> error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before
>>>> ‘GPJ_grass_to_osr’
>>>> /home/daniel/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:88:
>>>> error: expected declaration specifiers or ‘...’ before
>>>> ‘OGRSpatialReferenceH’
>>>> main.c: In function ‘main’:
>>>> main.c:281: warning: format not a string literal and no format arguments
>>>> main.c:296: warning: format not a string literal and no format arguments
>>>> main.c:376: warning: format not a string literal and no format arguments
>>>> main.c:379: warning: format not a string literal and no format arguments
>>>> main.c:391: warning: format not a string literal and no format arguments
>>>> main.c:485: warning: format not a string literal and no format arguments
>>>> main.c:497: warning: format not a string literal and no format arguments
>>>> main.c:560: warning: format not a string literal and no format arguments
>>>> main.c:579: warning: format not a string literal and no format arguments
>>>> main.c:596: warning: format not a string literal and no format arguments
>>>> main.c:757: warning: format not a string literal and no format arguments
>>>> main.c:1104: warning: format not a string literal and no format arguments
>>>> main.c: In function ‘scan_bounds’:
>>>> main.c:1127: warning: format not a string literal and no format arguments
>>>> main.c:1178: warning: format not a string literal and no format arguments
>>>> make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Scientist
>>> Landcare Research, New Zealand
Scientist
