[GRASS-user] r.stream.extract with external flow accumulation maps
    jentjr
    jentjr at gmail.com
    Sun Jun 26 20:56:42 EDT 2011
All,
I am trying to use r.stream.extract with the National Hydrography Dataset
Plus, which includes elevation, flow direction and flow accumulation maps. I
recently read the paper by Jasiewicz and Metz that states, "...network
modeling is based on accumulation maps that are created internally or
created with an external GIS software or as the result of map algebra."
However, I get the following when I try to use the module with the NHDPlus
data:
ERROR: Accumulation map does not match elevation map!
Should I be getting this error message?
Thank you,
Justin Jent
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-stream-extract-with-external-flow-accumulation-maps-tp6518518p6518518.html
Sent from the Grass - Users mailing list archive at Nabble.com.
