[GRASS-user] r.stream.extract with external flow accumulation maps
Johannes Radinger
jradinger at gmx.at
Mon Jun 27 02:03:06 EDT 2011
Am 27.06.2011 um 02:56 schrieb jentjr:
> All,
> I am trying to use r.stream.extract with the National Hydrography Dataset
> Plus, which includes elevation, flow direction and flow accumulation maps. I
> recently read the paper by Jasiewicz and Metz that states, "...network
> modeling is based on accumulation maps that are created internally or
> created with an external GIS software or as the result of map algebra."
> However, I get the following when I try to use the module with the NHDPlus
> data:
> ERROR: Accumulation map does not match elevation map!
I think you have to have all the input maps with the same spatial extend and the
same grid resolution to be able to process it with r.stream.*
Did you check for that?
/johannes
> Should I be getting this error message?
> Thank you,
> Justin Jent
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-stream-extract-with-external-flow-accumulation-maps-tp6518518p6518518.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
