[GRASS-user] r.univar.zonal install by g.extension
Alfredo Alessandrini
alfreale74 at gmail.com
Tue Jun 28 07:46:02 EDT 2011
I'm trying to install r.univar.zonal by g.extension but I get the
following error.
Thanks in advance,
Alfredo
GRASS 6.4.1 (WGS84_lat_long):~ > g.extension extension=r.univar.zonal
| grep error
WARNING: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
Compiling <r.univar.zonal>...
r.univar_main.c: In function 'main':
r.univar_main.c:83:24: warning: variable 'cols' set but not used
[-Wunused-but-set-variable]
r.univar_main.c:83:18: warning: variable 'rows' set but not used
r3.univar_main.c: In function 'main':
r3.univar_main.c:95:15: warning: variable 'use_zone' set but not used
ERROR: G_getenv(): Variable LOCATION_NAME not set
Installing <r.univar.zonal>...
make: *** No rule to make target `install'. Stop.
ERROR: Installation failed, sorry. Please check above error messages.
