[GRASS-user] Re: r.water.outlet and longitude / window issue
Andy Wickert
wickert at colorado.edu
Tue Jun 28 13:43:10 EDT 2011
OK - I think I figured out some of it. On my computer where r.water.outlet
DOES work, the west-longitudes are expressed as negative 0-180, while on the
computer where it doesn't work, they are expressed as positive
east-longitude 180-360.
So: the question becomes, how do I choose how west-longitudes are
interpreted by GRASS?
Thanks!
Andy
On Mon, Jun 27, 2011 at 11:00 PM, Andy Wickert <wickert at colorado.edu> wrote:
> Hi GRASS user-list,
> I think that I have run into a bug in either the computational window
> definition or the r.water.outlet program (or maybe something else) that has
> to do with defining degrees West as either positive (East-longitude >180) or
> negative.
> What happens is that, for example, I type:
> r.water.outlet drainage=$watershed_direction basin=temp_basin easting=196
> northing=60 --verbose --overwrite
> And GRASS returns:
> WARNING: Warning, ignoring point outside window:
> -164.0000,60.0000
> This occurs no matter whether I specify the longitude as a positive
> East-longitude (as above), as a negative value (e.g.,-164), or as, e.g.,
> 164W. (196E is not allowed).
> The problem is not my window definition, which includes the point in
> question:
> proj: 3
> zone: 0
> north: 73:00:30N
> south: 49:59:30N
> east: 144:59:30W
> west: 162:59:30E
> cols: 3121
> rows: 1381
> e-w resol: 0:01
> n-s resol: 0:01
> top: 1
> bottom: 0
> cols3: 3121
> rows3: 1381
> depths: 1
> e-w resol3: 0:01
> n-s resol3: 0:01
> t-b resol: 1
> When I use r.what, it gives me East-longitudes (values >180) for regions to
> the East of the 180 meridian. But r.water.outlet insists on switching
> everything to negatives no matter what input I give it, which I think is a
> source of the problem.
> The strangest thing about this is that I ran into this problem while
> following a routine that I had written several months ago in Bash; last
> time, I ran r.water.outlet on North America (all in degrees-west land) with
> no problems at all. I just checked the computational region (window) files
> for that run, and they look very similar to the ones I am using now. I have
> no clue why I didn't run into this problem back then / why it is cropping up
> now; both computers are running GRASS 6.4.1 on Ubuntu Linux.
> Anyway, if anyone has any suggestions, I'm all ears. Many thanks in
> advance,
> Andy Wickert
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110628/be46bcc5/attachment.html
