[GRASS-user] Re: Where should the file python-wxversion be located?
Thomas Adams Thomas.Adams at noaa.gov
Tue Jun 28 08:03:49 EDT 2011
  Problem resolved.
Thanks to all who responded; Justin your information helped a lot —
after the suggestions and even more digging and some more installs using
http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu (which may have
helped some in terms of my original problem of not getting wxpython to
work for me), but definitely helped to get additional capability in my
build.
In the end I had competing python installs: /usr/bin and /usr/local/bin
— so, I deleted the /usr/local/bin install of python; wx-config was only
present in /usr/bin
I strongly suggest new Umbutu GRASS users to follow
Tom
On 6/21/11 11:18 PM, jentjr wrote:
> Hi Tom,
> I'm not sure if this helps you, but I have GRASS7 running on Ubuntu 11.04
> and this is where python-wxversion is located on my machine.
> justinjent at ubuntu:~$ locate wxversion
> /usr/lib/python2.6/dist-packages/wxversion.py
> /usr/lib/python2.6/dist-packages/wxversion.pyc
> /usr/lib/python2.7/dist-packages/wxversion.py
> /usr/lib/python2.7/dist-packages/wxversion.pyc
> /usr/share/doc/python-wxversion
> /usr/share/doc/python-wxversion/changelog.Debian.gz
> /usr/share/doc/python-wxversion/copyright
> /usr/share/pyshared-data/python-wxversion
> /var/lib/dpkg/info/python-wxversion.list
> /var/lib/dpkg/info/python-wxversion.md5sums
> /var/lib/dpkg/info/python-wxversion.postinst
> /var/lib/dpkg/info/python-wxversion.preinst
> /var/lib/dpkg/info/python-wxversion.prerm
> justinjent at ubuntu:~$gedit /usr/share/pyshared-data/python-wxversion
> [python-package]
> format = 1
> python-version = 2.6, 2.7
> [pycentral]
> version = 0.6.11
> include-links = 0
> [files]
> /usr/lib/python2.6/dist-packages/wxversion.py=f
> /usr/lib/python2.7/dist-packages/wxversion.py=f
> I followed this page when I compiled GRASS7
> <http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu>
> Justin Jent
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Where-should-the-file-python-wxversion-be-located-tp6502667p6502776.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
