[GRASS-user] Ps.map vlegend
Hamish
hamish_b at yahoo.com
Wed Mar 2 20:28:55 EST 2011
Martin Album Ytre-Eide wrote:
> When using "area fill patterns" (http://grass.osgeo.org/wiki/AreaFillPatterns#Example_Pattern_files)
> together with vlegend in ps.map trouble appears when
> customising the patterns to my need. You can pretty much get
> the patterns you desire with the aid of pwith and scale
> option, but the problem is that vlegend does not follow up.
> Vlegend somewhat scales things down making the legend lock
> like something else than what is seen in the map. One can
> change the size of the legend by using width and fontsize
> but the pattern will still have the same size.
> Is there any solution to this problem other than generating
> your own legend?
please file it as a wish/bug in the trac system. I might not be
able to look at it for a few weeks, but don't want it to get
forgotten about.
I've seen something like this before and I figured out a fix for
it, but I'll have to remind myself how I did that.
thanks,
Hamish
