SV: [GRASS-user] Ps.map vlegend
Martin Album Ytre-Eide Martin.Album.Ytre-Eide at nrpa.no
Thu Mar 3 05:00:07 EST 2011
I started making my own legend, but I can't seem to make one with pattern :( The rectangle function does not accept a pat command. Any workaround or ideas?
Thanks,
Martin
-----Opprinnelig melding-----
Fra: Hamish [mailto:hamish_b at yahoo.com]
Sendt: 3. mars 2011 02:29
Til: grass-user at lists.osgeo.org; Martin Album Ytre-Eide
Emne: Re: [GRASS-user] Ps.map vlegend
Martin Album Ytre-Eide wrote:
> When using "area fill patterns"
> (http://grass.osgeo.org/wiki/AreaFillPatterns#Example_Pattern_files)
> together with vlegend in ps.map trouble appears when customising the
> patterns to my need. You can pretty much get the patterns you desire
> with the aid of pwith and scale option, but the problem is that
> vlegend does not follow up.
> Vlegend somewhat scales things down making the legend lock like
> something else than what is seen in the map. One can change the size
> of the legend by using width and fontsize but the pattern will still
> have the same size.
> Is there any solution to this problem other than generating your own
> legend?
please file it as a wish/bug in the trac system. I might not be able to look at it for a few weeks, but don't want it to get forgotten about.
I've seen something like this before and I figured out a fix for it, but I'll have to remind myself how I did that.
thanks,
Hamish
