[GRASS-user] Install Addon GRASS 7.0 on Mac
    Johannes Radinger
    JRadinger at gmx.at
    Thu Mar  3 03:12:49 EST 2011
hej,
Am 03.03.2011 um 07:01 schrieb Hamish:
> William wrote:
>> g.extension also changes how GRASS_ADDON_PATH is
>> interpreted, from GRASS 6 - it used to be a direct path to
>> the executable folder, ie bin/, now it's a path to the
>> parent of that.  The default user addon paths set by
>> the Mac startup are (GRASS version is major.minor version):
> It still should be a single path which points to a dir which should be
> added to GRASS's search $PATH.
> yes, g.extension is abusing it a bit using it like --prefix, but some
> months ago g.extension was reworked with a hack so a symlink to the
> executable made it into the real $GRASS_ADDON_PATH and not some
> support
> dir beneath it.
> it is far from ideal, but it should make it work.. at least when the
> install is built from a local compile. not sure how well tested it is
> outside of that (where Platform.make and friends need to point to the
> installed dir not the build dir, which doesn't exist on the end-users'
> computer)
> Hamish
It seems that my g.extension points to the build dir
rather then to the installation. So what should I do to install a add-
on which is executable
(globally) on my mac.?
I tried it also with /Library/GRASS/[GRASS version]/Modules/bin but i
still fail to compile and it still points to my build dir...
is there any other good way to install an add on on a mac?
maybe you can explain in detail how to do that, i really don't have a
clue after the readme...
/j
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
