[GRASS-user] v.in.ascii: Cannot Close Attribute Table
Rich Shepard rshepard at appl-ecosys.com
Fri Mar 4 19:22:52 EST 2011
On Fri, 4 Mar 2011, Martin Landa wrote:
> first, enable debugging
> g.gisenv set=DEBUG=5
> and re-run the command.
Martin,
Populating table...
D2/5: Commit transaction
D2/5: save_table 0
D2/5: save_table 1
D2/5: save_table 2
D2/5: Write table to tempfile:
'/home/rshepard/grassdata/Nevada-utm27/PERMANENT/.tmp/salmo/27870.dbf'
D2/5: Write 110339 rows
D2/5: Written 110339 records
D2/5: db_close_database() result: 0  (0 means success)
D2/5: db_shutdown_driver() failed
ERROR: Could not close attribute table. The DBMI driver did not accept all
        attributes
   So, it looks like the problem is within db_shutdown_driver(), eh?
> Which OS and DB driver you are using?
> db.connect -p
   Slackware-13.1/32-bit.
D2/5: dbDbmscap(): opendir [/usr/local/grass-6.5.svn/driver/db/]
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:
group:
Thanks,
Rich
