[GRASS-user] v.in.ascii: Cannot Close Attribute Table
Martin Landa
landa.martin at gmail.com
Fri Mar 4 14:18:58 EST 2011
2011/3/4 Rich Shepard <rshepard at appl-ecosys.com>:
> GRASS 6.5.svn (Nevada-utm27):~/grassdata > v.in.ascii -b --o
> in=/home/rshepard/GIS/data/Nevada/nv_wells.txt out=water_wells format=point
> fs='|' skip=1 columns='well_log varchar(8), x double precision, y double
> precision' x=2 y=3 z=0 cat=0
> Scanning input for column types...
> Maximum input row length: 39
> Maximum number of columns: 3
> Minimum number of columns: 3
> Column: 1 type: string length: 8
> Column: 2 type: double
> Column: 3 type: double
> Importing points...
> 100%
> Populating table...
> ERROR: Could not close attribute table. The DBMI driver did not accept all
> attributes
> The source table contains three columns: the well_log ID, utm_easting, and
> utm_northing. Seems to me that only the first would be an attribute for the
> table. How do I determine what the problem is?
first, enable debugging
g.gisenv set=DEBUG=5
and re-run the command.
Which OS and DB driver you are using?
db.connect -p
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
