[GRASS-user] db.out.ogr: Syntax Correction
Rich Shepard
rshepard at appl-ecosys.com
Sat Mar 12 15:32:18 EST 2011
On Sat, 12 Mar 2011, Micha Silver wrote:
>> nodes=26
>> points=0
> This ^^^^^^ is why the first run "db.out.ogr" failed
> And with area features db.out.ogr won't work.
Micha,
I had no idea of the limitations as I've not before tried to use it. I'm
sure that I'll encounter more db.* issues as I come to depend on them.
> You won't need the renamed copy. Once you have a new set of GRASS vectors
> with their attributes in postgres, chuck out the originals.
Thank you.
Rich
