[GRASS-user] Error while removing file
Mon Mar 14 16:00:05 EDT 2011
António Rocha wrote:
> I'm trying to remove a file named new_clump at Area and I get this error:
> [new_clump at Area] is a base map for [myscript.tmpV at Area]. Remove forced.
"is a base map for" is just a warning; it doesn't prevent removal so
long as the -f flag is given.
> misc: couldn't be removed
This indicates that there was some problem with removing the cell_misc
directory.
