[GRASS-user] Install Addon GRASS 7.0 on Mac
Johannes Radinger
JRadinger at gmx.at
Tue Mar 15 11:24:42 EDT 2011
Hello,
So I just wanted to know if there is any possibility to install
any add-on (r.stream.*) on my mac?
How can I do that without having my the source code anymore and
only the ready installed GRAS GIS 7.0?
It seems that g.extension is not working at the moment, or
is that problem already fixed in the latest weekly source?
thank you
/johannes
-------- Original-Nachricht --------
> Datum: Wed, 2 Mar 2011 10:38:01 -0600
> Von: William Kyngesburye <woklist at kyngchaos.com>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: Markus Neteler <neteler at osgeo.org>, grass-users at lists.osgeo.org
> Betreff: Re: [GRASS-user] Install Addon GRASS 7.0 on Mac
> >> Datum: Wed, 2 Mar 2011 15:14:24 +0100
> >> Von: Markus Neteler <neteler at osgeo.org>
> >> CC: kyngchaos at kyngchaos.com, grass-users at lists.osgeo.org
> >> On Wed, Mar 2, 2011 at 2:11 PM, Johannes Radinger <JRadinger at gmx.at>
> >> wrote:
> >>> Hello,
> >>> first great thanks to you William! My GRASS 7.0 is no perfectly
> running
> >>> on my Mac 10.6.6.
> >>> Now I want to install the r.stream addon. I tried with
> >>> g.extension extension=r.stream
> >> svnurl=https://svn.osgeo.org/grass/grass-addons/grass7
> prefix=$GRASS_ADDON_PATH
> >>> but I failed...
> >>> So what do I have to do?
> >> Tell us why it fails :) I.e. send the error message...
> > That's the error message I get:
> > Checked out revision 45518.
> > Compiling 'r.stream'...
> > make: stat: /users/admin/downloads/grass-7.0.svn_src_snapsho
> > t_2011_02_26/dist.i386-apple-darwin10.6.0: Permission denied
> > mkdir: /users/admin/downloads/grass-7.0.svn_src_snapshot_201
> > 1_02_26: Permission denied
> > make: *** [/users/admin/downloads/grass-7.0.svn_src_snapshot
> > _2011_02_26/dist.i386-apple-darwin10.6.0] Error 1
> > ERROR: Compilation failed, sorry. Please check above error messages.
> > mkdir -p
> /users/admin/downloads/grass-7.0.svn_src_snapshot_2011_02_26/dist.i386-apple-darwin10.6.0
> > (Wed Mar 2 15:25:18 2011) Command finished (8 sec)
> > Interestingly it mentions my download-directory where I compiled the
> grass-gis before... So is it not okay then to delete the downloaded
> source-snapshot after compiling and installing (at the moment it is still there).
> I've never tried g.extension before.
> That $GRASS_ADDON_PATH can have multiple paths in it, separated by :
> (colon). The Mac startup does just this. And it looks like g.extension doesn't
> handle this, so it's trying to create a bogus folder, though it should not
> be having permissions problem since it would still be in your home folder.
> Maybe the : separator is confusing the system (some Mac internals still
> use the old : file path separator).
> g.extension also changes how GRASS_ADDON_PATH is interpreted, from GRASS 6
> - it used to be a direct path to the executable folder, ie bin/, now it's
> a path to the parent of that. The default user addon paths set by the Mac
> startup are (GRASS version is major.minor version):
> ~/Library/GRASS/[GRASS version]/Modules/bin
> I didn't catch the change and haven't updated the Mac startup yet. Though
> it looks like the normal startup does both, which still gets it messed up.
> So, I'd say set the prefix=~/Library/GRASS/7.0/Modules for g.extension,
> but GRASS would not find your installed extension afterwards to execute it.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
Schon gehört? GMX hat einen genialen Phishing-Filter in die
Toolbar eingebaut! http://www.gmx.net/de/go/toolbar
