[GRASS-user] Re: open map
stephen sefick ssefick at gmail.com
Mon Mar 21 10:21:51 EDT 2011
GUI layer manager.  However if the projection doesn't match the
current mapset be careful.  This could signal problems.
On Mon, Mar 21, 2011 at 9:19 AM, Anja_Eva <badera at student.ethz.ch> wrote:
> Hey!
> <Is it in the same projection as the location?
> not exactly... I need a location around Belize in Central America and put in
> some coordinates which should covering the whole country. But the map from
> the internet is bigger I think.
> So I marked 'extend location extents based on new dataset'. Isn't that
> enough? ;-)
> <Have you imported it into GRASS with r.in.gdal or v.in.ogr? ...
> Yeah I tried it, but it said: Projection of dataset does not appear to match
> current location.
> Then I marked 'extend location extents based on new dataset'
> It said that the .bil format was not supported, so I tried with .hdr. Is
> this right? It said raster map created but how do I really display the map?
> Thanks
> Anja_Eva
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/open-map-tp6192258p6192403.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Stephen Sefick
____________________________________
| Auburn University                                         |
| Biological Sciences                                      |
| 331 Funchess Hall                                       |
| Auburn, Alabama                                         |
| 36849                                                           |
|___________________________________|
| sas0025 at auburn.edu                                  |
| http://www.auburn.edu/~sas0025                 |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
                                -K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
                              -Robert Gentleman
