[GRASS-user] interpolating images with coastal areas
Edgar Pimiento e_pimiento at yahoo.com
Mon Mar 21 20:58:36 EDT 2011
Hi Bulent,
Yes, I think it is better to treat the sea area as NULL data. One way to
interpolate the DEM is to use a mask corresponding to the land area, another way
is to replace the values of the sea with null data in the DEM.
Best,
Edgar Pimiento
To: Edgar Pimiento <e_pimiento at yahoo.com>
Sent: Mon, March 21, 2011 9:20:11 AM
Subject: Re: [GRASS-user] interpolating images with coastal areas
Hi Edgar,
Thank you for the explanation and suggestion. If I understand you correctly, you
suggest converting elevation values zero and below to NULL and use that 30m
resolution imagery for interpolation. So, this map should be used as MASK.
I hope I got it right?
Best,
Bulent
On Sun, Mar 20, 2011 at 3:14 PM, Edgar Pimiento <e_pimiento at yahoo.com> wrote:
>The problem is probably the data for the sea of the ASTER images. In some cases
>I have seen negative values for sea areas and extremely high values, errors
>also, in mountainous areas. For interpolating I think  it is better to treat the
>sea areas as no data values. Use the  land area as mask in the interpolation.
>You can also check the ASTER elevation data comparing with the corrected version
>of 90-m SRTM from http://srtm.csi.cgiar.org/
>Best,
> Edgar Pimiento Chamorro
>To: grass-user at lists.osgeo.org
>Sent: Mon, March 21, 2011 3:03:35 AM
>Subject: [GRASS-user] interpolating images with coastal areas
>Dear List,
>I am working on interpolating 30m ASTER DEMs to 10m resolution. I am using GRASS
>6.4.1 svn on Mac OS 10.6.6. Since the imagery covers a large area, I crop the
>30m DEM into individual tiles in order to make the project more manageable. The
>interpolation process (using v.surf.rst) has been working fine and the values in
>resultant 10m DEMs have been quite accurate, especially for inlands. However, I
>have some problems with interpolating tiles where coastline is present. In these
>tiles, the range of values in 10m DEMs go below zero. In some cases I have
>values such as -21 meters whereas the original –30m– tiles have only zero.
>Obviously, I am concerned about the accuracy of the end product.
>Do I get high negative values because of the cells with zero value?
>Should I zoom further in and avoid having zero-value cells? (which is a problem
>with coastlines where they are not straight)
>Does any one have a suggestion about how to deal with this problem?
>* I sample the original imagery at 50% in r.random,
>* I use the default parameter values in v.surf.rst (tension= 40.) and use the
>30m DEM as MASKMAP,
>* I align region to resolution, using g.region.
>Thanks!
>BÜLENT
BÜLENT ARIKAN, PhD
Postdoctoral Scholar
Center for Social Dynamics and Complexity &
School of Human Evolution and Social Change
Arizona State University
Tempe - AZ
85287-2402
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110321/2023e475/attachment-0001.html
