[GRASS-user] How to extract z-coordiante and write it into
attribute table?
Vincent Bain
bain at toraval.fr
Wed Mar 23 09:33:42 EDT 2011
If your map is a 3d vector, v.db.connect will do the job.
First create 3 new numeric fields in the table (x,y,z), run v.db.connect
with the coord option : it will feed these attributes.
Then you can drop x,y columns if you don't need them anymore.
Vincent
Le mercredi 23 mars 2011 à 06:29 -0700, TimNorwey a écrit :
> Hey,
> I have a point cloud and I would need the z-coordinate of each point as
> attribute. Is there a possibility to extract the z-coordinate and write the
> corresponding value into the attribute table of each point?
> Thanks,
> Tim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-extract-z-coordiante-and-write-it-into-attribute-table-tp6199821p6199821.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
