[GRASS-user] Re: How to extract z-coordiante and write it into
attribute table?
TimNorwey
timmy_weyrer at live.at
Wed Mar 23 10:29:14 EDT 2011
Vincent Bain wrote:
> If your map is a 3d vector, v.db.connect will do the job.
> First create 3 new numeric fields in the table (x,y,z), run v.db.connect
> with the coord option : it will feed these attributes.
> Then you can drop x,y columns if you don't need them anymore.
Thank you for you quick answer.
I added the the columns, but I can´t find the coord option within
v.db.connect?
Thanks,
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-extract-z-coordiante-and-write-it-into-attribute-table-tp6199821p6200459.html
Sent from the Grass - Users mailing list archive at Nabble.com.
