[GRASS-user] Re: How to extract z-coordiante and write it into attribute table?
Vincent Bain bain at toraval.fr
Wed Mar 23 10:35:14 EDT 2011
Tim,
sorry for the mistake, I meant v.to.db
(with option=coor and columns=x,y,z)
Vincent
Le mercredi 23 mars 2011 à 07:29 -0700, TimNorwey a écrit :
> Vincent Bain wrote:
> > If your map is a 3d vector, v.db.connect will do the job.
> > First create 3 new numeric fields in the table (x,y,z), run v.db.connect
> > with the coord option : it will feed these attributes.
> > Then you can drop x,y columns if you don't need them anymore.
> Thank you for you quick answer.
> I added the the columns, but I can´t find the coord option within
> v.db.connect?
> Thanks,
> Tim
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-extract-z-coordiante-and-write-it-into-attribute-table-tp6199821p6200459.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
