[GRASS-user] simple shell scrip example with parameters
Markus Neteler
neteler at osgeo.org
Fri Mar 25 04:11:16 EDT 2011
I have taken Daniel's example and own and added them to the
related Wiki page:
http://grass.osgeo.org/wiki/GRASS_and_Shell
Feel free to add more there.
Markus
On Wed, Mar 23, 2011 at 11:28 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Not sure this is the best way to do but, if you are using bash in
> linux, the variables $1 $2 and so on are the parameters you pass to
> the script. So, if you have a script called basin.sh and you type
> basin.sh -23 -47
> the variable $1 will be -23 and $2 will be -47...
> so in your script you could put
> r.water.outlet drainadge=your_map basin=basin_map easting=$2 northing=$1
> you could also pass a third parameter for the basin map name...
> Here is a good online tutorial for bash scripting
> http://www.linuxconfig.org/Bash_scripting_Tutorial
> Boa sorte
> Daniel
> On Tue, Mar 22, 2011 at 5:25 PM, Marcello Benigno
> <benigno.marcello at gmail.com> wrote:
>> Hi All,
>> I need build one script shell for GRASS that receive two parameters (x and y
>> coordinates) and calculate the r.water.outlet to this point, but I'm newbie
>> in shell programming. Anyone have a example or link to show something
>> similar? In my tests I can run one simple script, without parameters, and
>> now thats the point.
>> Thanks in advance,
>> Marcello Benigno B. de Barros Filho
>> Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
>> Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
>> http://profmarcello.blogspot.com
>> http://about.me/marcello.benigno
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
