[GRASS-user] GDAL-GRASS Error
Chethan S
chethanuniversal at gmail.com
Mon May 2 09:01:26 EDT 2011
Hi all,
When I run --with-grass=/usr/local/grass-6.5.svn, for installing GDAL-GRASS,
I get the following error:
checking for gdal-config... /usr/bin/gdal-config
using /usr/lib/gdalplugins as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/usr/local/grass-6.5.svn requested, but
libraries not found!
Perhaps you need to set LD_LIBRARY_PATH to include /usr/local/grass-6.5.svn/lib?
I have created a *grass.conf* as instructed elsewhere inside
/etc/ld.so.conf.d/ and have added following lines in it:
/usr/local/lib
I ran sudo ldconfig after that too.
I came across a similar issue posted in the GRASS-Dev mailing list
<http://osgeo-org.1803224.n2.nabble.com/gdal-grass-plugin-build-failed-td6232215>.
As an answer it was instructed to:
You could just generate the symlinks yourself, e.g.:
cd /usr/local/grass-6.5.svn/lib
for file in libgrass_*.so ; do ln -s $file ${file%.6.5.svn.so}.so
; done html.
I ran,
but it made no difference! What should I do now?
Thanks and Regards,
Chethan S.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110502/7841df31/attachment.html
