[GRASS-user] GDAL-GRASS Error
    Markus Neteler
    neteler at osgeo.org
    Mon May  2 16:26:13 EDT 2011
On Mon, May 2, 2011 at 3:01 PM, Chethan S <chethanuniversal at gmail.com> wrote:
> Hi all,
> When I run --with-grass=/usr/local/grass-6.5.svn, for installing GDAL-GRASS,
> I get the following error:
> checking for gdal-config... /usr/bin/gdal-config
> using /usr/lib/gdalplugins as GDAL shared library autoload directory
> checking for G_asprintf in -lgrass_gis... no
> configure: error: --with-grass=/usr/local/grass-6.5.svn requested, but
> libraries not found!
> Perhaps you need to set LD_LIBRARY_PATH to include
> /usr/local/grass-6.5.svn/lib?
Above problem was a temporary mess which has been fixed since then:
See http://trac.osgeo.org/grass/changeset/46104
I wonder why 6.5 is lacking this fix.
Markus
