[GRASS-user] winGrass, ODBC and Oracle
Markus Neteler
neteler at osgeo.org
Mon May 9 18:43:12 EDT 2011
On Fri, Apr 29, 2011 at 8:37 AM, Sharon M <morrisxs09 at gmail.com> wrote:
> Hi,
> I'm running winGrass 6.4.1 on winXP and trying to use the wingrass ODBC
> driver to connect to an Oracle database.
> I've used db.login and db.connect to define the database and user. When I
> run db.tables -p a windows pops up with an error message:
> Error odbc.exe has encounted a problem and needs to close
That will likely be the odbc driver.
> Do any winGrass versions - 6.4.1 or 6.5 or 7 - work with the Grass ODBC
> driver and Oracle?
> Also, are any of the Windows precompiled binaries available with the ODBC
> driver?
No experience ... maybe it is worth to ask on the OSGeo4W list?
Markus
> Any help on this would be appreciated because I'd like to move my attribute
> tables from the dbf driver.
> Thanks in advance,
> Sharon
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
