[GRASS-user] winGrass, ODBC and Oracle
Sharon M
morrisxs09 at gmail.com
Tue May 10 02:11:23 EDT 2011
Thanks for the OSGeo4W hint.
Looked at the GDAL pages and winGrass release notes with reference to GDAL
here:
http://grass.osgeo.org/grass64/binary/mswindows/native/#Release_Notes . I
wonder if GDAL needs to be compiled with Oracle option? I'm well out of my
depth here.
Sharon
On Tue, May 10, 2011 at 8:13 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Apr 29, 2011 at 8:37 AM, Sharon M <morrisxs09 at gmail.com> wrote:
> > Hi,
> > I'm running winGrass 6.4.1 on winXP and trying to use the wingrass ODBC
> > driver to connect to an Oracle database.
> > I've used db.login and db.connect to define the database and user. When I
> > run db.tables -p a windows pops up with an error message:
> > Error odbc.exe has encounted a problem and needs to close
> That will likely be the odbc driver.
> > Do any winGrass versions - 6.4.1 or 6.5 or 7 - work with the Grass ODBC
> > driver and Oracle?
> > Also, are any of the Windows precompiled binaries available with the ODBC
> > driver?
> No experience ... maybe it is worth to ask on the OSGeo4W list?
> Markus
> > Any help on this would be appreciated because I'd like to move my
> attribute
> > tables from the dbf driver.
> > Thanks in advance,
> > Sharon
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110510/f8afa997/attachment.html
