[GRASS-user] i.atcorr: icdn with aerosol optical depth (AOD)
Gaspar Reyes Póndigo
gos47 at hotmail.com
Sun May 15 15:50:02 EDT 2011
VERY THANKS Markus.
The solution of the two lines is fine, perfect. Its work
Example of " correct code for ICDN" when it is estimated of aerosol optical depth without data of visibility.
7 # geometrical conditions
01 25 16.63 -96.676 15.758 # data general
1 # atmospheric mode
2 # aerosol mode
0 # visibility
0.112 # aerosol optical depth 550 nm
-0.192523 # mean target elevation above sea level [km]
-1000 # sensor on board a satellite
28 # spectral band
El 15/05/2011, a las 14:10, Markus Neteler escribió:
> 2011/5/15 Gaspar Reyes Póndigo <gos47 en hotmail.com>:
>> Dear List
>> I changed the value V=0 0.112 to V=0, 0.112, but the error persists: "WARNING: Unsupported iwave value: 1606111984".
>> There any way (equation) to transform the AOD toVisibility?
> I contacted Yann Chemin who gave me the solution:
> Instead of
> 0 0.112
> or
> v=0, 0.112
> make it two lines:
> 0
> 0.112
> and it shall work...
> Will update the documentation accordingly.
> Cheers
> Markus
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110515/0359ee1c/attachment.html
