[GRASS-user] SUM: NVIZ Solution
Michael Morin
mmorin at cassblue.com
Sun May 15 18:07:45 EDT 2011
My original post:
Hello techies,
I have a 7.5 min SDTS grid that I exported from ESRI Arcview as an ASCII Arc/Info GRID. I imported the GRID into Grass...used Elevation Color map and all works fine. I invoke NVIZ using the same raster as the elevation image and I get a blank in my nviz window....error in Command Window is the following:
(Sat May 14 20:11:02 2011)
nviz elevation=salsburydem at PERMANENT
Raster map <salsburydem at PERMANENT> is outside of current region. Load failed.
Loading raster map <salsburydem at PERMANENT>...
Error finding range
I am new to Grass having been and ESRI guy for 30 yrs so I am wondering what I might be doing wrong to get this 3D surface to draw?
I thank you all in advance.
The solution:
Date: Sat, 14 May 2011 23:55:47 -0700 (PDT)
Subject: [GRASS-user] Re: nviz...3D Raster
To: grass-user at lists.osgeo.org
Message-ID: <1305442547602-6364962.post at n2.nabble.com>
Content-Type: text/plain; charset=us-ascii
You forgot:
g.region rast=salsburydem at PERMANENT
Thank you Martin!
Michael D. Morin
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110515/3534c34c/attachment-0001.html
