[GRASS-user] Re: i.atcorr returns all NULL values
Chemin, Yann (IWMI)
Y.Chemin at cgiar.org
Sun May 15 23:48:29 EDT 2011
Can you please share your scripts (both i.landsat.toar and i.atcorr)
please.
Also can you share the .met or _MTL.txt that came with your failing
Landsat image.
Finally, the r.info output for one of the band that is failing in
i.atcorr.
Thank you,
Yann
-----Original Message-----
[mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Elena Mezzini
Sent: Saturday, May 14, 2011 12:14 AM
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Re: i.atcorr returns all NULL values
I have the same problem, both with band 1 and 2.
I did i.landsat.toar and then i.atcorr but all the bands worked except
for band 1 and 2, these have values min=-nan and max=-nan.
There is someone who can help us?
Thank you!
Elena
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/i-atcorr-returns-all-NULL-values-
tp4975543p6360527.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
