[GRASS-user] Re: i.atcorr returns all NULL values
Elena Mezzini
elena.mezzini at gmail.com
Mon May 16 12:26:05 EDT 2011
Can you please share your scripts (both i.landsat.toar and i.atcorr)
please.
Also can you share the .met or _MTL.txt that came with your failing
Landsat image.
Finally, the r.info output for one of the band that is failing in
i.atcorr.
Thank you,
Yann
Here they are:
I used i.atcorr.fast that now is the implemented i.atcorr in GRASS 6.5.xx
(Markus gave it to me).
http://osgeo-org.1803224.n2.nabble.com/file/n6369333/i.atcorr.fast
i.atcorr.fast
http://osgeo-org.1803224.n2.nabble.com/file/n6369333/i.landsat.toar
i.landsat.toar
http://osgeo-org.1803224.n2.nabble.com/file/n6369333/L5192030_03020090723_MTL.txt
http://osgeo-org.1803224.n2.nabble.com/file/n6369333/rinfoerrb1.txt
rinfoerrb1.txt
Now I will try with the GRASS 6.5.xx version. It seems that with that one it
works!
Thank you!
Elena
View this message in context: http://osgeo-org.1803224.n2.nabble.com/i-atcorr-returns-all-NULL-values-tp4975543p6369333.html
Sent from the Grass - Users mailing list archive at Nabble.com.
