[GRASS-user] GRASS GDAL 1.4.3 error in installing
Chethan S.
chethanuniversal at gmail.com
Mon May 16 23:51:28 EDT 2011
Hi all!
When I tried installing GDAL-GRASS-1.4.3 on GRASS 6.5.SVN running in Ubuntu
11.04, configure and make steps run fine. But when I use 'sudo make install'
I get this error:
install -d /usr/lib/gdalplugins
cp gdal_GRASS.so /usr/lib/gdalplugins
cp ogr_GRASS.so /usr/lib/gdalplugins
test -d /usr/local/share/gdal/grass || mkdir /usr/local/share/gdal/grass
mkdir: cannot create directory `/usr/local/share/gdal/grass': No such file
or directory
make: *** [install] Error 1
What is to be done for this?
Regards,
Chethan S.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110517/6607ebae/attachment.html
