[GRASS-user] nviz script don't work
Maris Nartiss maris.gis at gmail.com
Wed May 18 02:32:09 EDT 2011
Hello,
At first - can You use NVIZ without any scripting?
If Yes, then can You, please, send me script file off list? I can take
a look at it.
Some NVIZ parts are quite fragile and thus might be accidentally broken.
Maris.
2011/5/17, Bornemisza Imre <born at freemail.hu>:
> Hi, dear GRASS-Users,
> do you have idea, why nviz my fly-script don&#39;t plays?
> Environment:
> VMware Player 3.1.3 build-324285 (on WinXP)
> (because I haven&#39;t access to install a "real" Linux)
> Ubuntu 10.04.2-desktop-i386 (because 11.04 was instable)
> the install command was on the just installed Ubuntu:
> sudo apt-get install gdal-bin grass grass-doc
> GRASS version: 6.4.0RC5
> script was made by d.nviz, the running commands:
> d.nviz -ice input=elevation.dem output=fly_01 dist=3000 ht=2000 frames=1000
> nviz command:nviz elevation=elevation.dem vect=roads color=landuse
> script=fly_01.nvscr
> nviz answers:
> Loading raster map <elevation.dem at PERMANENT>...
> 100%
> Loading raster map <landuse at PERMANENT>...
> 100%
> Vector map <roads at PERMANENT> loaded (757 features)
> Entering script mode ...
> DONE!
> , but nothing moves.
> (If the answer in the Archives,
> send me please the URL and the method to find it next time.)
> Thanks for your help:
> Imre Bornemisza - born_AT_freemail_DOT_hu
