[GRASS-user] Manually Defining Location
Bryan Keith
bkeith at itascadenver.com
Fri May 20 18:01:53 EDT 2011
Rich,
I'm not convinced that's a valid wkt description of the coordinate
system you want.
If I convert that to proj.4, I get
+proj=longlat +ellps=clrk66 +datum=NAD27 +no_defs
which is clearly wrong.
If I use the GRASS location wizard and point it to that wkt, it thinks it is
+proj=longlat
+no_defs
+a=6378206.4
+rf=294.9786982
+towgs84=-22.000,157.000,176.000
which is also clearly wrong.
If I try to manually make a proj.4 string from that wkt, I come up with this:
+proj=tmerc +lat_0=34.75 +lon_0=-115.583333 +k=0.9999
+x_0=152400.3048006096 +y_0=-609601.21920243837 +ellps=clrk66
+datum=NAD27 +units=us-ft +no_defs
Check my numbers there because maybe I did something wrong. When I
use that proj.4 to convert your coordinates, the results are
cs2cs -f %0.6f +proj=tmerc +lat_0=34.75 +lon_0=-115.583333 +k=0.9999
+datum=NAD27 +units=us-ft +no_defs +to +init=epsg:4326
371801.76 427253.14
-116.051661 41.414985 0.000000
which is SW of
41.87 N, -115.43 W
but I understand that you think you should be NW of that point....
Don't know if this helps or just adds confusion.
Bryan
On Fri, May 20, 2011 at 15:50, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Fri, 20 May 2011, Rich Shepard wrote:
>> GEOGCS["GCS_North_American_1927",
>> DATUM["D_North_American_1927",
>> SPHEROID["Clarke_1866",6378206.4,294.9786982]],
>> PRIMEM["Greenwich",0.0],
>> UNIT["Degree",0.0174532925199433]],
> I now understand that the above is angular units. However, the problem
> that the location wizard wants local units in meters for tmerc, nad27 rather
> than US feet remains.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
