SV: [GRASS-user] Modifying Vector Attribute Table Values
Martin Album Ytre-Eide Martin.Album.Ytre-Eide at nrpa.no
Tue May 24 02:33:49 EDT 2011
My advise to you: use mysql or postgres. In linux it is very easy to install both of these. I think it is easiest to start with mysql, but postgres is somewhat better. So if you have good time and will do a lot with vector maps - go for postgres (which also have the very interesting postgis feature). If you want get on in a hurry - go for mysql with the phpmyadmin interface. Mysql: install lamp (linux, apache, mysql, php) and phpmyadmin. For postgres - I like the pgadmin3 interface.
You should look at some basic tutorial as well.
Change the database - it's worth the effort.(use db.connect for each mapset before you import the maps) It will save you some headache. I do all my queries in the database-interface and connect the maps to views or new tables with v.db.connect.
Good luck.
Martin
-----Opprinnelig melding-----
Fra: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] På vegne av Rich Shepard
Sendt: 24. mai 2011 02:00
Til: grass-users at lists.osgeo.org
Emne: Re: [GRASS-user] Modifying Vector Attribute Table Values
On Mon, 23 May 2011, Rich Shepard wrote:
>  In GRASS-6.x is there a way to modify the data in the default .dbf
> vector attribute tables?
   This is interesting. I opened the .dbf in OO.o and there are the county names in the attribute column, 'NAMES'. When I query the table with the db.* tools I don't see the names, only the numbers in the previous two columns.
   Also, when I try to export the table I see errors and nothing is exported:
GRASS 6.5.svn (Nevada-aea):~/grassdata > db.out.ogr in=county_bnd dsn=/home/rshepard/counties for=CSV
WARNING: The map contains islands. To preserve them in the output map, use
          the -c flag
WARNING: 47 boundary(ies) found, but not requested to be exported. Verify
          'type' parameter.
WARNING: 17 centroid(s) found, but not requested to be exported. Verify
          'type' parameter.
WARNING: 17 areas found, but not requested to be exported. Verify 'type'
          parameter.
WARNING: No points found, but requested to be exported. Will skip this
          geometry type.
WARNING: Nothing to export
   If I'm asking for attribute data to be exported from the .dbf why do I get errors about geographic attributes?
Confused, but wanting to learn,
Rich
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
