[GRASS-user] Modifying Vector Attribute Table Values
Rich Shepard
rshepard at appl-ecosys.com
Tue May 24 09:32:33 EDT 2011
On Tue, 24 May 2011, Micha Silver wrote:
> db.out.ogr is a wrapper around v.out.ogr, which forces "type=point". SInce your county_bnd is probably a
> polygon layer, you probably want to export to CSV the centroids (which hold the attrib data). Try this:
> v.out.ogr county_bnd olayer=county_bnd dsn=/home/rshepard/counties format=CSV type=centroid
Toda, Micha. I did not know to use the centroid type because I've not used
the db.* modules before.
Rich
