[GRASS-user] LiDAR LAS import
Markus Metz
markus.metz.giswork at googlemail.com
Wed May 25 07:48:19 EDT 2011
On Wed, May 25, 2011 at 12:16 PM, Hamish <hamish_b at yahoo.com> wrote:
> Markus Metz wrote:
>> Hi all,
>> GRASS 7 has a new module v.in.lidar for importing LiDAR LAS files
>> (*.las or *.laz). The LAS file format is commonly used for storing
>> LiDAR point clouds, but is unfortunately not supported by OGR.
>> v.in.lidar uses the libLAS library [0] and is only compiled if the
>> libLAS library is present.
>> I chose to use the library instead of writing a custom LAS reading
>> interface because the current LAS library version 1.6.1 is stable,
>> supports LAS file versions 1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, each of
>> which can store LiDAR points in up to 5 different point formats. The
>> user and the interface do not need to know the file version and point
>> format of a given file, all that is conveniently handled by the libLAS
>> library in the background. The library has Large File Support (LFS)
>> and is well tested on different platforms, also with different
>> endian-ness. This functionality is not that easy to replicate.
>> You will need to get the libLAS library and configure GRASS 7 with
>> --with-liblas in order to have the module available. Please test!
>> Markus M
>> [0] http://www.liblas.org
> neat! any time trials to say how much faster it is than piping
> las2txt | v.in.ascii
Note that las2txt does NOT apply scale and offset to x,y,z, this would
need to be done afterwards in order to obtain correct coordinates.
Therefore the output of las2txt | v.in.ascii with the sample las file
I used is incorrect.
I discovered a bug in v.in.ascii: from a point file with | as field
separator like
1|2|3||5|6
only the first 3 columns will be imported because column 4 is empty
which means that columns 5 and 6 are skipped.
v.in.lidar is a notch faster than las2txt | v.in.ascii. And easier to use...
Speed comparisons:
# sample las file with 1,287,775 points
# with table and topology
time las2txt -i points.las --stdout --parse xyztinrcCpedRGBau
--delimiter "|" | v.in.ascii in=- out=points_ascii -z x=1 y=2 z=3 --o
real 6m34.430s
user 4m57.530s
sys 2m3.693s
time v.in.lidar in=points.las out=points_las -o --o
real 6m13.823s
user 4m32.061s
sys 2m1.068s
# without table, with topology
time las2txt -i points.las --stdout --parse xyz --delimiter "|" |
v.in.ascii in=- out=points_ascii -zt x=1 y=2 z=3 --o
real 1m53.578s
user 1m47.032s
sys 0m9.238s
time v.in.lidar in=points.las out=points_las -ot --o
real 1m44.876s
user 1m34.450s
sys 0m8.488s
