[GRASS-user] Re: [GRASS-dev] LiDAR LAS import
    Pierre Roudier
    pierre.roudier at gmail.com
    Thu May 26 02:23:16 EDT 2011
Hi Markus,
Just compiled again liblas svn trunk, everything is working as expected so far.
Thanks heaps for that new functionality, this is really very useful.
Pierre
2011/5/25 Markus Metz <markus.metz.giswork at googlemail.com>:
> Hi all,
> GRASS 7 has a new module v.in.lidar for importing LiDAR LAS files
> (*.las or *.laz). The LAS file format is commonly used for storing
> LiDAR point clouds, but is unfortunately not supported by OGR.
> v.in.lidar uses the libLAS library [0] and is only compiled if the
> libLAS library is present.
> I chose to use the library instead of writing a custom LAS reading
> interface because the current LAS library version 1.6.1 is stable,
> supports LAS file versions 1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, each of
> which can store LiDAR points in up to 5 different point formats. The
> user and the interface do not need to know the file version and point
> format of a given file, all that is conveniently handled by the libLAS
> library in the background. The library has Large File Support (LFS)
> and is well tested on different platforms, also with different
> endian-ness. This functionality is not that easy to replicate.
> You will need to get the libLAS library and configure GRASS 7 with
> --with-liblas in order to have the module available. Please test!
> Markus M
> [0] http://www.liblas.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Scientist
Landcare Research, New Zealand
